Pflow particles and phoenix
I always have trouble using the particles in pflow to make explosions any basic setup iI could get some pointers on
Thanks in advance
Hey,
Particles without geometry will not affect the fluid’s motion by default, so you need to enable Motion velocity checkbox in the Phoenix Source explicitly if you need this effect.
The other thing you might need to tweak is the Particle shape options - by default it’s set to Sphere, 1 voxel - each particle will be the size of one grid cell. Particle sizes and shapes will be ignored.
You can find more about it here - Chaos Docs
Cheers,
thank you give it a try
