im getting unhandle exception error rendering a simple animation of 20particles. The particles are shape instanced sphere with a noise modifier. The problem only appears when render the animation.
How can i fix this problem.
The first frame always render perfect, the error pop up starting the second frame.
Error message: Unhandled eception: preparing instances.
3dmax 2009 SP1 creativity extension + Vray 1.5 SP2
I think the problem is related to the noise modifier, If i disable it the render goes ok.
But i need the noise animation. What can i do?
Which object is the Noise modifier applied on?
Maybe the error message is displaced due to an overflow of your memory limitation of 1.7GB per application, if working on a x86 (32-bit) OS.
