Phoenix water don't render
I simulated 200 frames water, it’s good. After restart windows 10 system, the water in 3dsmax viewport is good, but when render there the water is empty.
I recreate a new test scene in max and render the water no problem,
please help me how to resolve. Thanks.
Hey,
Check your Rendering rollout and make sure the render Mode is set to Mesh. Also make sure the Simulator is renderable from it’s right click Object Properties and it has a proper material assigned.
Cheers!
Oh, Thank you Svetlin !
