Hello
Some problem with rendered picture in VFB and denoising. If I have unticked option “Clear VFB inbetween renders”, I’d like to see last rendered picture when render starts and see changes there. There no problem with that if denoising is switched off, but if it’s on, VFB shows last denpised picture each time render starts even if I rendered some pictures and canceled denoising.
Maybe it will be more clear if you reproduce this workflow:
Render picture and let Corona to denoise it. Change something and render region or full picture again, this time cancel render without denoising. Start render again -not denoised picture will be replaced by denoised picture which we rendered first. If you stop denoising in the middle of the process, picture which will replace rendered picture in VFB will be kind a bled of denoised and not denoised pictures
It is not convenient when I want to render some region of a big size picture and tweak for example color of some object there, denoising in that case could take pretty much time especially if lightmixer’s layers should be denoised too, but it’s important to see the progress of changes.
