If you look at my attached image…
The sun passes over the walls and creates shadows everywhere.
I tried to move the sun without obtaining the desired result.
I would like to make sure that the sun comes through the windows and not through the non-existing ceiling…
Thanks for your help !
You can unhide/or make the ceiling and set its object properties to be invisible to camera…that should do it.
I added a plane as ceiling and in its properties, I don’t see any invisibility properties ?
It’s okay ! I found it !
Right Click and “Object Properties”
Thanks !
It doesn’t seem to work… maybe I have something wrong, I thought the idea was good !
Please take a look at my attachments…
Thanks !
You’ve unchecked everything else, so no it won’t work like this. The only thinng you need to uncheck is ‘visible to camera’
