Possibility to change or scale Enscape assets
Is it possible to make it so that fabrics and different finishes can be applied to Enscape assets? As well as being able to adjust their width, depth, height. I work for an interior design firm and this would be very helpful.
Hi @JessOH welcome to our forum!
I have moved your post to a new thread.
It is not possible to change the Enscape assets but I have added your vote to this request.
With our upcoming version 2.9 it will be possible to create your own assets however, the release is set for the beginning of November.
You can scale our assets, this is currently not possible in ArchiCAD and Vectorworks.
So I am also having another issue I need help with immediately. I have emailed feedback and reached out yesterday but no reply. I am needing this figured out today. would you be able to help me or should I continue waiting? It regards my window mullions or grids not showing up in Enscape but they show up in Revit.
@JessOH can you post a screenshot or file to check?
I have emailed the file to Enscape Support already but here is a screenshot.
Are these windows turned on in the view you are rendering in Enscape? At the left side of the Enscape ribbon, it shows you wish 3d view in Revit you are syncing in Enscape and it may not be your current view you are using. Maybe you are rendering a 3d view where these windows are turned off.
I really can’t tell without the file. Hope it helps
do you need me to email the file? I am in the view and its synced but it still doesn’t show the mullions.
@JessOH sorry for the late reply. Yes if you didn’t solve this yet, I will try to help if you send the file.
what’s your email
Absolutely agree .. the ability to scale component and change materials is gonna be a big help. I cant seems to find a good queen bed in the asset library.
hit the first ‘arrow’ button again if the live update is broken - hope it helps/ work for me all the time :slight_smile:
