Hi there,
I’ve recently purchased and built 2 PC’s of which I specified a low/mid tier card; AMD Radeon RX 560 (Sapphire) and honestly - I wasn’t hoping for great live quality from Enscape with them but; I was wrong. Fortunately they work great - being just about able to navigate a live project with ultra settings.
However, I feel I may have uncovered a problem with output resolutions in Enscape and these cards specifically;
When exporting an image or video with the same quality settings as the live navigation I get a very glitched image.
After we toyed with the settings to try and find out what was causing the problem we found that: **selecting one of the predefined resolutions (**so “4k” all the way down to “1024x768”) produced the same glitched result.
However, when selecting the “Window” option and increasing the size of the window to the maximum (1080p I guess, minus the top window bar) both images and video outputs work perfectly.
Please can you shine any light on this issue? I feel that if it was a problem with the card i.e. not good enough or faulty - then I wouldn’t be able to output at the window resolution option either - which in theory is better than the “1024x768” & “720p” presets? Please let me know if i’m misunderstanding the way the resolutions work.
Either way I thought I’d share.
To be clear; we are running Mid/High tier Nvidia Cards elsewhere in the office all of which I am unable to replicate the same issues - they all work fine regardless of settings.
I’ve attached 3 images of the same scene rendered in there different resolution presents.
