haven’t posted anything in awhile. this is from about a year ago and i’m just now able to show it.
And the reference image…
Pole
Crazy! What was it for?
its for a litigation case. the pole was poorly put together and the wires were rubbing together causing sparks to fly everywhere. it started a fire that burned a few hundred thousand acres. i have an animation of the wires rubbing and sparking…i’ll see if i can post it.
-joe
amazing the uses people find for cg these days!
Hey that’s pretty cool! Especially that toonversion.
Really, really nice
what a bizarre job to get!
thanks for the comments. this is actually a very typical job for us
though i admit, the litigation viz business can have some strange subject matter at times.
-joe
Very cool. But why would the client need a 3d rendering practically identical to a photo?
well the animation is what they paid for. if you look at the reference image you can see that it is slightly different than the still. the reference image shows the pole after the line snapped. the animation shows the lines rubbing, sparking and snapping…then falling into the position as seen in the reference image.
the stills shown above weren’t really used by the client…its just the 1st frame of the animation. i’ll be able to show the ani when i get around to posting it on our site ![]()
thanks
-joe
Ah, I see. I haven’t met anyone here doing litigation visualisation. Sounds quite interesting though. Maybe the litigious nature of U.S. jurisprudence requires more of this type of work.
I would love to see the animation! You’ve done a top notch job on matching the model to the reference photo.
yep really great job mathicng the image. thumbs up!
Nice Work. So how does the litigation visualization business Pay? ![]()
If the animation looks as good as the still, I’d really want to see it.
I’d say the reference image is a bit softer, which I think looks better.
thanks again for the comments.
here it is animated: 3dspeedmachine.com
it looks a little different than the still. its been awhile since i worked on this case and i forgot that i had to turn off displacement for the animation. i never did like the look of certian things, like the sparks, but that wasn’t up to me.
@ drjan: now that you mention it i agree…softer looks better. i recall adding some sharpening to the still in post
@ mhenry: i cant complain ![]()
Ha! that’s great. I think I need to look into this line of work… ![]()
EDIT: Sorry, no pun intended, initially
