presentation
model presented in white mode only, where materials aren’t exported from Revit file, such bricks, concrete and others
Hey @Maisko ! Welcome to the Enscape Forum!
I’m not sure if what you’re telling us is intended or not. There is a “White Mode” in Enscape you can enable or disable (in the Visual Settings / Main Tab). But it sounds like you’re expecting materials to be exported from Revit? If so, do you mean the Graphics Tab or the Appearance Tab? There is a setting in Enscape you can use to switch between the two. Am I on the right track here?
