As the title says; it doesn’t render properly
max 2011 sp1
vray 2.40.04
bercom tiles
Not tested yet with the new vray3
attached image and scene.
test materiales-11 displacement_MT.zip (36.4 KB)
max 2011 sp1
vray 2.40.04
bercom tiles
And you’re sure all pcs have the same version of bercontile and multitexture installed on them and that all computers read the map locations from a UNC share?
Hi svetlozar, i attached the scene with textures , on the previous file i didn’t include them. VraySpawner are started as window service and “restart slaves on render end” its on.
Morne, yes , all have the same version, is the first time i use them, so i have no other versions.
test materiales-11 displacement_MTa.zip (6.3 MB)
I think what Svetlozar meant was that the maps have to be accessible from a network location, UNC paths.
For example \\server\textures\stone\stone01.jpg. It looks to me like your servers are trying to read the maps from a local drive (Y:), probably where they were on the machine where you submitted from. As the maps aren’t locally on the render slaves it will produce errors.
Al textures are accessible from the network.
I use mapping drives for ages (that letter Y: is for a map drive); that being said , DR always worked fine that way.
solve: different multitextures versions on the slaves
Thanks for the feedback ![]()
