Problem with 3.1 and VR (oculus quest 2)
hi, I installed the trial version 3.1 and I have a problem when activating vr with the oculus quest 2, the image looks very very shaky and washed out, unlike version 3.0, which works ok. Thank you, I hope it is temporary bug.
Hi @Arquipablo
Welcome to our forum!
As we do not officially support the Oculus Quest (2), please have a look at the thread here.
pcorrea77 is correct. I can confirm the same bug. Downgrading from 3.1. to 3.0.2 created a completely different experience in VR using the Oculus Quest 2. Behavior is the same in both wired Oculus rift link and wireless Oculus Air link: the image is washed out and the controller tracking results in a very shaky experience. Makes one dizzy.
In 3.0.2 mode, the controller tracking is completely stable.
i can confirm the stutter… but if i turn the Nvidia RTX Render Off, all is smooth … Using 3.1 ! I use a 3060 newest driver …
I’m seeing the stutter in a normal Rift in the standalone executable. This is 3.1 with a 3080, newest driver…
I can also confirm that turning off RTX fixes this issue. I didn’t expect settings for the main app to change anything in the standalone export.
Hey. I’m having problems with three computers at the office experiencing the same problem. We run everthing from 1070 to 3070 cards with updated drives and are all expericing the same issue with our Quest 1. No difference with RTX on or off and as the 1070 card doesn’t have RTX the issue shouldn’t be connected to that? The headset is one of the common factors, could it be the problem?
You can also try to acquire and install Enscape 3.1, as 3.2 currently seems to present an extraordinary amount of shaking on some machines which we’re in the process of resolving. If you still experience this behavior with 3.1 or even 3.0, then please let me know and also send us a dedicated Feedback Report from those machines on which you experience this. Also, just to mention it as well, some lag and stutters could be completely normal on the GTX 1070 depending on the resolution, framerate, and Rendering Quality (Can be adjusted in the Visual Settings in the first tab) used since that GPU is basically only partially ideal for VR in larger scenes especially.
Hi Damian. I tried 3.0 and it works fine. I’ll give 3.1 a try and will stay on eather of those for a while until the issue is resolved. Thanks for your help.
Hehe, 3.1 still has this issue Batch rendering issue so I’ll have to go to 3.0
