So only a fragment of the *.aur-file has to be loaded?
yes, this is technically no problem. now even if you have reduced preview, it loads and uncompresses the entire data, that is slow.
Problem with Anim Index
Ivaylo!
Aaaargh, so here I have the problem with changing the playspeed again! Remember?
Here is a preview of my scene:
You see that there are jerks and jumps in the sim.
I animated the Anim Index - but at the moment it does no changes -I have a stright line from -100/-100 to 2000/2000 - what means that I do not have any timechange at the moment - but the jerks happen…
This makes my blood freeze - I have to deliver end of february!
Heeeeelp… ![]()
I hoped that it would not happen on render, but here is the renderresult:
It´s even worse! The anim is really jerky!
AAAARGH!
What do you think could be the problem?
- I have sims starting at -100
- I have multiple sims with different sim-start-stopframes (I just deleted all except one - no changes)
- I set the playspeed to 0 and use only the anim index (tried this, doesn´t change)
- I also reduced the simulation-speed (not playspeed)
- Max 2012
Wow, I really need a solution for this or I really get in trouble!
Do you have any ideas for fixing / workaround?
I´ll try to reproduce it with a simple scene…
Thank you Ivaylo!
Doesn´t the Anim Index use blending? Only the Play speed?
I cannot reproduce. Could it be that these may be frames where I paused the sim to testrender or to render a preview? Or maybe restoring? I did this several times, especially when max crahsed…
I think you can just restart your sim with timescale animation. That should fix the problem, if no other soluions are found.
the anim index uses also blending
Hi Paul.
Thank you for answering!
Yes, I also thought of that - that may be a solution, but it would be very, very uncomfortable and time-consuming - I would have to simulate A LOT of unecessary frames - each time I have to retime.
Testing this solution would cost days…
That would definitely endanger my deadline!
btw, what blending method you are using?
Both…
…with the same result…
Now I´m checking if only the moving simulators are affected…
Maybe it has to do with the adaptive grid?
Yeah, that seems to be the problem…
…I think I can reproduce now…
omg, isn’t the frame blending not forbidden with adaptive grid?!
Isn´t it not forbidden - therefore allowed? Or is it forbidden? I do not find anything about that in the documentation…
Does it mean that if I want to use Playspeed / Anim index - I cannot use the adaptive grid?
That would destroy my whole setup and I have to begin from scratch…
it should be forbidden, no way to blend frames with different size.
Shhhh…
That´s really evil…
Alarm…
Okay, two ways to solve this:
- Make everything without adaptive grid
- Use adaptive grid but animate the speed with time scale in dynamics
Second solution will not work, because I have nearly 1000 Objects influencing the sims - and therefore I would have to retime them all at once - which is not managable - at least with max 2012, 2013 has some new retiming-features, but I cannot change the whole pipeline 2 weeks before deadline…
Please, add this information to the documentation - that might have saved me from running into this trap.
Or better a warning-popup whenever activating the adaptive grid…
…like with the shellac-mode in the vray-blend material…
yes,some notification is really missed. or we can try to improve the blending to work with adaptive grid
