Problem with refraction max depth
I recently discovered a thread about the max depth issue in reflections in GPU rendering (GPU Production rendering ignores material reflection max depth when using metalness).
It got solved 2019. I have kind of the same issue with refractions atm. Settings above a certain number get ignored (6-8). Is there any workaround possible without switching to CPU?
Thank you for your help
Quick update: I was trying to replicate the issue on a new scene but it looks like its working as expected.
Hi H_923874​,
Can you please share the following information:
  • The versions of V-Ray and Cinema 4D you are currently using
  • A video demonstrating the problem or some screenshots
  • A scene file where the issue is reproducible.
Please note that you can share all the information here in the forum, or submit a ticket in our support system if you prefer.
