I’ve found that if there is no filename in the Render Dialog / Common Tab / Render Output / Save File field then the file will not be saved out when you call render from maxscript with a file name while using the Vray VFB.
it will save out the file you specify in the ‘outputfile:’ option of the render function , but the contents will be blank.
It works fine if you have the VrayVFB off and no filename saved in the render common dialog
it also works fine if you have the VrayVFB ON and have *any* filename saved in the render common dialog.
So i pretty much just check the rendOutputFilename property in my script and set it to a temporary value while doing the render call in max, and then blank it out again after the render is over.
Yes, David, this is to be expected. If you are using the V-Ray VFB, and there is no save to file specified in the Render Scene dialog, V-Ray will not generate the 3dsmax VFB at all. Since it is the 3dsmax VFB that gets saved when you specify the ‘outputfile’ option, it is to be expected that it is blank in that case.
everything looks as expected during lightcache and IRRmap calculations, but the actual render is a solid gray color, without any shadows, highlights or anything at all… just a solid color.
the same scene worked fine with RTT last week… so I know this is probably some setting i have accidently changed… but I just cant fint which one.
edit: using rc2. vray framebuffer with “save separate render channels” enabled.
It’s hard to say what may be different; if you don’t manage to solve this, you can send me your scene to vlado@chaosgroup.com so that we can take a look.
