Render to Texture - crash
Hi there,
I made a plane as ground, a box and a vray light, chose the box, hit “0” to bring up the “Render to texture” dialogue.
Made a completemap, and assigned to diffuse slot. Hit render in the bottom of the dialogue.
Max crashes.
Tried it in:
max 2016/vray 3.3
max 2016/vray 3.5
max 2017/vray 3.5
Running win10-64bit.
Hope to hear from you vray wizards soon.
Best, Jesper Colding
Animator
You must make sure its Vraycompletemap as there is a default one which vray does not support, if in doubt only use the channels with vray in front of it ie. VrayDiffuseFilterMap, VrayNormalsMap, VrayCompleteMap etc…
I hope this helps,.
Cheers.
