Problem with rendered texture in Enscape from Substance Alchemist Stody12
Hello there,
I have created material in Revit 2019 from Substance Alchemist and added them into Revit as base map, Normal map and Roughness map and add that texture into 3d revit and its showimg me right as you can see below in attached 1.jpg
](https://forum.enscape3d.com/wcf/index.php?attachment/14959-1-jpg/)
And as you can see here below in attached 2.jpg in Enscape it’s rendering as white or grey out and without any similarity with my 3d in revit. It seems like Enscape cant recognize this material, but Revit can.
](https://forum.enscape3d.com/wcf/index.php?attachment/14960-2-jpg/)
I m also attaching my used textures for this. Could you please help me, why i cant render this texture properly?
Many thanks
texture.zip (2.87 MB)
Unfortunatly I can’t see your screenshots.
You probably want to use the Glossiness input and invert your roughness map:
The gloss map, a simple color inversion:
