ok i give in
were installing sp1 onto the render servers and it basically comes up with the standard missing vray plugins bla bla bla when trying to render. the plugins are in the correct folders after install
using max2008 64bit. vray 2008 64bit
remote server
our max licenses work fine finding the dongles
ive tried installing rendernode and full install and still no dice
any ideas.
if i use 1.50 it works fine
the vray server uses 1.5 sp1
any help would be great
oh yeah ive uninstalled and rebooted and reinstalled to try and get it to work
Check the plugin.ini file in the root folder of 3ds Max (not the one in Document and Settings etc) and make sure that the line about additional V-Ray plugins is the last one.
yup checked the plugin.ini file all good there but not the 32bit enu folder
theres certainly some strange things going on in 64bit max where as max 32bit just seems to work fine.
do a search for all plugin.ini files,
then make sure the 64bit plugin.ini points to the right directory with the 64bit vrayplugins directory
same goes for 32 bit
Are you using XP64 or Vista? If your using Vista have you tried installing the vray sp1 exe file from your desktop by right clicking and choosing run as Administrator?
Then you can try to uninstall the 1.5 version, make sure all v-ray plugins (from the “vrayplugins” folder) are also removed, and then install the service pack. If that still does not work, can you email me your plugin.ini file from the root folder of 3ds Max to me at vlado@chaosgroup.com so that I can take a look?
