vray 1.5 issue (probably user error :s)
hi.
i’ve just done a new install of vray 1.5 using viz2008 but the plugins for vrayplan, sun, sky, etc.. aren’t loading on startup.
probably something i’ve done wrong i should think - been a while since i set a new machine up :roll:
In the file plugin.ini in the root folder of 3ds Max, make sure that the line “Additional V-Ray plugins…” is the last one in the directories list.
thanks vlado.
ini file was correct.
unfortunately i think it’s a vista issue.
plugins will load fine when i run viz as administrator…
f’kin vista! aaaarghhh!!! :evil:
