Proxy crash max
Hello, sorry for my bad English, i found strange bug, Corona 1.6 + 3ds max 2018, programm crash if the object Coronaproxy open the Modify tab
](http://www.imgzilla.ru/view-image/19b7a57531fb3e6d905610f44d98c68c.jpg)
If you are able to reproduce this, could you send us a minidump generated from the crash? Here is how to do it: https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
Also, could you describe step-by-step what exactly you are doing to trigger this error?
This should be fixed in the latest daily build (1.7 Daily Builds Changelog - Corona for 3ds Max :: Previews (Daily Builds) - Chaos Forum) - I tested here, and Proxy causes crash in 2018 with 1.6, but with the daily build (due to be 1.6 hotfix 1), there was no crash. If you could test and confirm with the daily build, that would be great!
