Proxy display mode wrong on load
Since moving to VRay 3, whenever I load a scene using proxies, more often than not the proxies are shown as (solid) bounding boxes, even though the proxy itself says it’s in “preview from file” mode. Switching to a different mode and back again fixes the problem, but this is a bit tedious to do each time I load a scene! Is this a known issue?
It’s the first time I see it mentioned. Can you tell me which 3ds Max and V-Ray versions you are using? Are the proxies old (i.e. created with previous versions of V-Ray) or new?
Had the same problem, didn’t find a solution apart from writing a script that re-sets the display mode.
http://forums.chaosgroup.com/showthread.php?79708
It seems like this might be a Forest Pro problem. I saved out one proxy and when I re-opened it, it was ok. I went back and deleted one Forest Pro object and it was still busted, so I deleted all of them, re-opened and it was fine.
We’re using Max 2015 64 Design with VRay (whatever the latest is - 3.3?). All the proxies were saved out with previous versions.
ot but there is a simillar problems with lines viewport display.
If you have renderable lines and you set them to not to show in viewport (uncheck “enable in viewport”) and then render, after render finishes all lines thicknesses will be displayed in the viewport as if “enable in viewport” is checked.
Very anoying if you have lots of renderable lines.
Would it be possible to provide a scene or step-by-step guide how we could reproduce that issue into our environment in the same way like you did in yours?
