proxy not rendering
Hi all,
quick weird problem.
have an adapted xfrog mesh that I have change materials in and then proxied, for the life of me I cannot get it to render after proxying.. proxing in this file works with other assets and I have tried exporting and reimporting the poly model etc..
any ideas???
What version of Vray are you on?
What scale is the Vray proxy set to?
If you are on 2.40.03 and you are not with 1.0 scale, your render will not render in the same position as in max viewport…
That’s the main reason why we haven’t switched to 2.40.04, all the scene that we have still going on with proxy created with .03 will not render correctly if we update to .04
I tried and it was a nightmare, so we reverted back to .03
I’m waiting for vray 3 and then we will have to bite the bullet, but it will be worth it :wink:
Stan
Can you send us this file for investigation ?
Please include also the original mesh before proxy-conversion.
Thank you in advance.
Will do.. had to render it without proxing.. it wasn’t a scale thing
