Hi everyone,
Greetings! I’m not new to sketchup but a starter in Vray SU. The tutorials helped me a lot and i can follow it smoothly. But there’s 1 thing that i cannot deal with.. its about Vray sunlight. switching sunlight in SU is easy but for Vray sun is not. I can’t even make the Vray sun parameters to appear.
A bunch of tips and help is greatly appreciated. Thanks all!
Hi - the V-Ray sun in sketchup should be directly linked to your Sketchup sun position. The settings for the V-Ray sun can be modified in our Options - Environment slot. The GI and BG texture maps are, by default, set to Sky Textures. You should be able to modify the V-Ray sun-specific settings from there.
The V-Ray sun is based off of physical units…This means that the sun is very bright. It is recommended to use the physical camera so that you can properly expose the sun. For more info on the physical sun and the physical camera check out the vray training manual available in our downloads section.
This generally has to do with exposure settings in the physical camera. First - make sure you do have the physical camera on. You can find that in Options-Camera. The physical camera is based upon…well… a physical camera. This means that it uses exposure to control the amount of light in the final image. So, as with a real camera, you will need to tweak your shutter speed and f-stop to properly expose your “film”.
Another question i would like to clarify, does switching GI ON automatically uses the Vray sun or should a sky texture map should be added to the GI to use the Vray sun?
Again, i have gained knowledge.. 8)
I’m beginning now to test render using Vray sun and hopefully to have a greater depth of knowledge as i explore it. it would not all be possible without you guys! Thanks for all the help masters!
hope to hear again from you guys. till my next querry.
