question to sampling, passes, image resolution, hd cache
I made some testing with the settings of sampling, passes, image resolution.
I could find out that
..increasing the path tracing samples reduces noise and leads to better image quality
..increasing the rendering passes reduces noise and leads to better image quality
..increasing the image resolution it’s possible to lower the path tracing samples and/or rendering passes.
Can someone explain exactly the context between the three mentiond settings.
What are good settings for resolutions from width 800pix to 1600pix? What for resolutions from width 2000pix to 4000pix and what for greater than 4000pix?
Another question: Is HD Cache view dependant or not?
Thanks for answering.
Regards
Daniel Krüger
