RailClone Proxy objects
Hello
I set up a RailClone preset that arrays cars for large car park scenes. Not wanting to have all the cars loaded in the scene, as full meshes, I used Proxys. These render fine in CPU Vray, but in Vantage the cars only show the proxy mesh. Is there a way of getting this to work?
Does it render correctly if you render it with V-Ray Standalone (choose Export and render in the .vrscene export dialog) ?
If not, this is most likely a V-Ray for 3dsMax export issue, not a Vantage issue.
In any case, we will need a scene to figure out what the issue is.
Are you using V-Ray Proxy or some kind of 3dsMax Proxy ?
Greetings,
Vladimir Nedev
Hi Vladimir - I don’t have access to Vray Standalone in my office to test that out, however I’m just using regular Vray Proxies. As a test - I made a Railclone row of proxied Teapots and the same thing occurs
Can you attach this test scene here for us to test with ?
Greetings,
Vladimir Nedev
Hello - sorry for the delay. Here’s a simple scene with a Teapot proxy used in a RailClone array. I did try making the Railclone Viewport display Full Mesh, but that didn’t help (3DS Max 2024):
Test​
Interestingly the same proxy teapot will render correctly in a Forest Pack array in Vantage - just not in RailClone.​
Hi bruce_hart,
I tested your scene and saw that the .vrscene you attached is exported with V-Ray 6, update 2. I have made a new export with V-Ray 7 and the issue is not present there. You can also try to change the preview type of the proxy itself to show whole mesh. Can you try to update V-Ray on your end or the preview type to see if it resolves?
Alexander
Hey Alexander - thanks for your time, looking at it. I need to rely on my IT department to create deployments, and they are quite understaffed - hence the reason I’m behind in the versions. That’s great news in works in Vray 7. Thanks again
