I was saving views from Enscape to Revit 2020 yesterday. When I came back to the project today went into the views created in Enscape and random items were hidden or gone from the view. Enscape assest people, trees, some times it was materials. It happened in all 3 views I created. If I go to another view from Revit the items are there, nothing new was added after the saves.
I’ve seen this issue a couple of times. It required restarting Revit & Enscape and then things showed up again.
I finally figure it out. There was a co-worker working in a seperate area of the file and I was adding thing to a Revit workset called Renderings and he was adding thing to the normal Architectural workset. The Rendering workset was set to not visible in all views. After turning on the workset everything showed up correctly. Very annoying
