Hidden Objects Showing In Saved View REVIT
Hi!
I have hidden a few objects in Revit that at first appeared hidden in Enscape. I saved the view and came back to it today but now all the objects have reappeared on Enscape but are still hidden in Revit. Any way to fix this? I’ve started up Enscape on the Revit view that has all the objects hidden but when I switch to the saved view, they all come back.
EDIT: Looks like I can only get rid of it in the view if I delete the object… can’t do that though.
If you select a different view in View Management and then reselect the view with the hidden objects does Escape properly refresh the view? Also make sure the Export Geometry option is turned on.
