Read me first: List of all feature requests
Please don’t create new feature request threads, unless you cannot find your feature request on this list.
This is a comprehensive list of all the pending feature requests in this forum. It serves for a quick overview of the requested features for both the developers and users.
If there is a request in the forums that is not in this list and it’s older than one week, please let me know through a private message.
Post-process:
Save lightmix settings into camera or scene - save light mix with camera - Corona for C4D :: Wishlist - Chaos Forum
Don’t apply post-process to both images in A/B comparison - Cooperation of post effects and A/B comparisons - Corona for C4D :: Wishlist - Chaos Forum
Apply post-process only on certain objects (maybe mask-based?) - Exclude an object of post effects - Corona for C4D :: Wishlist - Chaos Forum
Displacement:
Cache for displaced geometry - holding displacement in memory? - Corona for C4D :: Wishlist - Chaos Forum
Global displacement toggle - https://forum.corona-renderer.com/index.php/topic,11453.0.html
Displacement preview in viewport - Viewport preview for materials with black diffuse - Corona for C4D :: Wishlist - Chaos Forum
Vector displacement - Vector Displacement - Corona for C4D :: Wishlist - Chaos Forum
Multi-pass:
Multipass settings to render settings -
Put Multi-pass into render settings - Corona for C4D :: Wishlist - Chaos Forum
Z-Depth - Corona for C4D :: Wishlist - Chaos Forum
Make depth in ZDepth pass able to use camera focal distance - ZDepth - Use Camera Focal Distance - Corona for C4D :: Wishlist - Chaos Forum
Materials:
Option to show material channels in viewport for Corona Mat. (a.k.a. Editor tab in Corona material) - Editor settings in material editor - Corona for C4D :: Wishlist - Chaos Forum
Simple material presets - Simple Carpaint Shader - Corona for C4D :: Wishlist - Chaos Forum
Max corona shader preset importer - https://forum.corona-renderer.com/index.php/topic,11244.0.html
Various material editor UI changes - Material Editor - Corona for C4D :: Wishlist - Chaos Forum
Exclude material from material override - override material exclusion by material - Corona for C4D :: Wishlist - Chaos Forum
Maxwell to Corona material converter - a material converter from maxwell render - Corona for C4D :: Wishlist - Chaos Forum
Substance to Corona material converter - Viewport preview for materials with black diffuse - Corona for C4D :: Wishlist - Chaos Forum
Layered material
Layered material copying/saving/loading - Fast way to save materialm, especially layered - Corona for C4D :: Wishlist - Chaos Forum
Layered material ignores Material IDs - Multipass from Layered Material - Corona for C4D :: Wishlist - Chaos Forum
Re-arranging layers in layered material - Layered Shader: Re-Arranging Layers - Corona for C4D :: General - Chaos Forum
Shaders and maps:
New falloff shader with more controls - Complex falloff - Corona for C4D :: Wishlist - Chaos Forum
Possibility to use image alpha in opacity channel map - https://forum.corona-renderer.com/index.php/topic,14063.0.html
Color variance shader (e.g. different color per instance) - variance shader - Corona for C4D :: Wishlist - Chaos Forum
Invert checkbox for some material maps - Map invert options - Corona for C4D :: Wishlist - Chaos Forum
Add a hue slider to Corona Output shader - enhanced corona bitmap loader - Corona for C4D :: Wishlist - Chaos Forum
Curvature shader - Curvature Shader - Corona for C4D :: Wishlist - Chaos Forum
Fresnel curve for control over fresnel reflectivity -
https://forum.corona-renderer.com/index.php/topic,14803.0.html
https://forum.corona-renderer.com/index.php/topic,12206.0.html
Lights and sky:
Emission texture for Corona light - https://forum.corona-renderer.com/index.php/topic,13607.0.html
Corona sky with texture slot for easy HDRI setup - https://forum.corona-renderer.com/index.php/topic,13713.0.html
Viewport:
Better viewport material preview -
https://forum.corona-renderer.com/index.php/topic,14793.0.html
Preview AO unoccluded shader in viewport - https://forum.corona-renderer.com/index.php/topic,13969.0.html
Corona proxy:
Quick exporting of data for Corona proxy - https://forum.corona-renderer.com/index.php/topic,11232.0.html
Corona proxy vs. polygon selection tag - https://forum.corona-renderer.com/index.php/topic,14944.0.html
Faster proxy handling, better proxy preview - https://forum.corona-renderer.com/index.php/topic,13002.0.html
Simple tweaks:
Temperature in light material - https://forum.corona-renderer.com/index.php/topic,12353.0.html
Render to viewport respects camera limits - https://forum.corona-renderer.com/index.php/topic,11292.0.html
Place Corona shader menu directly to Create material menu - https://forum.corona-renderer.com/index.php/topic,13476.0.html
AO shader would fill-in subshader if placed over existing shader - https://forum.corona-renderer.com/index.php/topic,13969.0.html
Miscellaneous:
Support for high-res rendering - https://forum.corona-renderer.com/index.php/topic,12342.0.html
Official license server integration - https://forum.corona-renderer.com/index.php/topic,11184.0.html
Spline and point render - https://forum.corona-renderer.com/index.php/topic,14919.0.html
Dump EXR for all animation frames - https://forum.corona-renderer.com/index.php/topic,15796.0.html
Support for foreground (and other object primitives) - https://forum.corona-renderer.com/index.php/topic,15842.0.html
Show noise level on TR clients - https://forum.corona-renderer.com/index.php/topic,15918.0/topicseen.html
Texture baking - https://forum.corona-renderer.com/index.php/topic,14727.0.html
Camera perspective correction - https://forum.corona-renderer.com/index.php/topic,16562.0.html
Incremental scene processing in animations - https://forum.corona-renderer.com/index.php/topic,16991.0.html
Corona VFB docking - https://forum.corona-renderer.com/ Dock corona VFB
Needs support in CoronaCore:
Export of post-process settings to LUT - https://forum.corona-renderer.com/index.php/topic,15310.0.html
Sky with volumetrics - https://forum.corona-renderer.com/index.php/topic,14920.0.html
Complex reflectance function - Complex falloff - Corona for C4D :: Wishlist - Chaos Forum
What will be done:
Render selected object -
https://forum.corona-renderer.com/index.php/topic,11179.0.html
https://forum.corona-renderer.com/index.php/topic,11440.0.html
https://forum.corona-renderer.com/index.php/topic,15765.0.html
Node based material editor -
https://forum.corona-renderer.com/index.php/topic,13311.0.html
Front/back material - https://forum.corona-renderer.com/index.php/topic,11701.0.html
Interactive render -
https://forum.corona-renderer.com/index.php/topic,13585.0.html
https://forum.corona-renderer.com/index.php/topic,14921.0.html
Light lister - https://forum.corona-renderer.com/index.php/topic,14093.0.html
Deformation motion blur - https://forum.corona-renderer.com/index.php/topic,14022.0.html
Heterogenous media (and VDB support) - https://forum.corona-renderer.com/index.php/topic,13469.0.html
Togglable layers in layered material - https://forum.corona-renderer.com/index.php/topic,15507.0.html
Texture mixing - https://forum.corona-renderer.com/index.php/topic,14809.0.html
Hair shader - https://forum.corona-renderer.com/index.php/topic,11829.0.html
Shadowcatcher material
What we will probably not gonna do (unless something changes):
Texture mapping in Corona bitmap instead of only in texture tag - https://forum.corona-renderer.com/index.php/topic,15193.0.html
Multiple IR views at once - https://forum.corona-renderer.com/index.php/topic,13997.0.html
