Its been a while since i’ve had to try this but is there a way to render each light and then use post to animate them flickering on n off seperately from each other?
I’ve set up the light mix passes so that I have a pass for every light but when i compare them to the beauty its always missing a bit of refraction, reflection or a bit of brightness that the beauty has.
what i have is beauty as a layer to compare against. then all the light passes are set to “lighten” in photoshop (the other options were too bright or too dim, lighten is the closest i have found) these give similar results but there is a bit of reflection/refraction missing.
I’ve uploaded an example of beauty vs lightmix passes comped on very simple test scene. What is the workflow for rebuilding this correctly in corona? I tested with PNGs, would I be better off just animating lights in Corona, the idea was to have more freedom in post.
