Reduce Noise when using UNIVERSAL settings?
Hi all
When using UNIVERSAL settings, is the only QUICK way to reduce noise, to lower the noise threshold?
I know there are other ways when you’re NOT using universal, but in this case I want to know specific for universal.
Depends on where the noise is coming from, but you can try increasing the min. shading rate in V-Ray 3
It seems mostly from GI
(Vray 2.4)
Then you can try increasing the GI subdivs perhaps?
I’ve got Global subdivs multiplier on 0 for this one ( min samples 8 )
What GI setup you are using ? Irr map, LC or Bruteforce?
BF primary, LC secondary
For V-Ray 2.x the only way I think is to lower the Noise threshold value and force more camera rays to be traced.
As vlado mentioned above , in V-Ray 3.0 there is an option “Min Shading rate” which could help.
