I have a vraymaterial which is reflective and I am using a skydome as a background. The problem is that the image on the skydome is not being reflected in my glass material. Does anyone have a suggestion? Thanks. http://www.thevizgroup.com/tim-1.htm
Also, I attach images so infrequently they never come out properly. I just end up having the link?? How do I attach the image directly to the post?
first of all… use fresnel reflection
second , use a modified skydome for the reflection slot…
i don’t know what a skydome is… but when i add a background in enviroment with the option “screen” i have the same effect as you…
and this with all render engines i use…
You probably have the Environment Override checked within the VRay Render settings. It’s best if you post a screen shot of your material and render settings so we don’t have to guess at all the possibilities.
Thanks for the replies - I ended up using fakiosity and it turned out O.K. When I slow down a little bit I will figure out the problem. Thanks again for the posts.
