Region IR with set passes wont continue after moving
Hi.
I don’t know if people have wrote about this already but:
I had set Interactive Rendering max passes to 50.
I just wanted to check some very small parts from my model with IR/Region and as the small area hits 50 passes,
the IR stops. My suggestion / request: Could it be possible for the IR to start again if the region is moved to another place?
Best regards
Agree, this annoys me as well.
Also, It would be great if we can use “noise level limit” with IR.
I believe both of these are valid feature requests. First one (pass limit + region render in IR) was already discussed, and as far as I remember there were some technical problems with it, but hopefully this can be solved.
Noise limit for IR is an interesting idea!
“The” noise limit was removed from IR for exactly that OPs reason.
And it still makes no sense as long as no one is able to predict (or reliable compare) what noise values will be calculated when using max region, selection, cVFB regions or any other mix regulary used with IR. Well at least I´m not :smiley:
Good Luck
P.S.: As for max passes: Why not just set it to 0 and let it run as long as you want.
