Hi everyone
Is that possible to render a section cut??? is anyone have any ideas to get this effect??? ![]()
Hi everyone
Re: Render a Section Cut
Canāt be done simply in vray. But you can transfer the bits that you donāt want to see onto a layer that you turn off (if you donāt want to destroy your model). Vray doesnāt render the turned off layers.
dās right. Thereās only one way I know how to pull this off, but you have to modify/isolate/delete SU geometry. youāll need this ruby script: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/SectionCutFace.rb I usually make a copy of my model just tbe sure I donāt screw the original up.
I could show you how, if youād likeā¦
I would be interested in this as I normally plan the construction of a model early with wall and areas on layers I will turn off! makes for a flexible modelā¦but my lord some planning is needed to make sure its rightā¦
Kind Regards
Mat
tsubiaddict- youāre much better off planning this out in advance; while itās just adds to the complexity of the modeling process, the end result is much cleaner and easier to control. What I was proposing to show juan.carlos.rioja was a process of retrofitting an existing construct with a sectional view. To accomplish this quickly youād have to explode any group or component that intersects the section plane. Otherwise, you would reconstruct those groups/components in 2 separate pieces so one side could be isolated for the section renderā¦obviously this would be a more time-consuming proposition.
Anyway, here is a very sloppy, simplified method of accomplishing this task. Bear in mind, this is not the ONLY way to do thisā¦but, you may be able to adapt this method to work for you.
1. make a copy of my model file just to make sure you donāt screw up the original.
2. create a section plane in SU and move it where you want the cut.
3a. select the section plane, right click, and select āAdd Section-Cut Faceā (the link to the ruby script is earlier in this thread).
3b. select whatever options you want in the dialog box.
4a. double-click the new group that the script made to go into group editing mode, Ctrl-A, and unhide all.
4b. explode the section face group.
5a. select the section plane alone, and rotate it 180 degrees. you should now see the geometry you wan to omit.
5b. this is the tricky partā¦carefully delete or isolate all the geometry on the āomitā side of the section plane. I would use parallel projection for this part to make the selections a little easier. when youāre finished all you should see is the exploded section plane we created earlier with the script.
6. after deleting/isolating the omitted geometry, you can delete the section plane, and also paint that section face however you want.
Thatās itā¦I know itās dirty and watered-down, but it works. Hope that helpsā¦good luck!
thanks for that break down, this could be very useful. question: how do you import the ruby script into sketchup so that this function can be used? i have the extensions turned on and can see the ruby console.
Navigate to the plugins directory for SU⦠I think itās āC:/Program Files/Google/Google SketchUp 6/Plugins/ā and move the ruby file in there. Make sure any instance of SU is closed, then start it again and the new ruby should automatically load.
Now, youāll have that new command called āAdd Section-cut Faceā, but since itās context sensitive, youāll only see it when youāve selected a SU section plane and right-click to bring up the context menu.
By the way, you rarely ever need to have the ruby console open; thatās really more for debugging broken scripts.
thanks to everyone⦠all your ideas are very helpfull ;D
Word. Good lookin out.
Thank you so much! ![]()
That fix my question!
Nice input KC! ![]()
Hi everyone, Iām a beginner with vray
Iāve just found this old topic and Itās quite close to what I 'd like to do : Is there a way to have such a cross section in an orthographic view (without the distorsion that Iāll get with a perspective effect)? Any helps would be really appreciate?
In Sketchup go to Camera menu, and select āParallel Projectionā. That should do it.
Hi my friends.. iāve some problem to render the section.. so..
Iāve a big model, that is inserted in a place with other buildings.. there are many grops in the model.
When do the sectioncutface.. and explode it, i need to intersect those face with the model? But.. there are the groups, and the intersect, doesnāt affect the inside of them. When go inside, canāt erase (after remove the section plane) the other side that i donāt wanna see.
I need to explode all the groups in my model?? this is a trouble.. first, because there are many and many groups, and second.. because the groups are necessary to do a cleaned work, with materialā¦
So.. what can i do??
thanks in advance (and sorry for my english..)
Thanks 40th for your answer. But unfortunately I tried this alreadyā¦even if I choose this camera Iāll had a blank image . The only thing that I manage to set is a different kind of color mapping which give me a āhalucinogenishā render (my grey turn to purple for exemple). I mean if I use a setting good enough for any other camera I would not have the same result (light global illumination) with an orthographic one an dthe same setting. I really donāt have a clue on what to doā¦? any suggestion knowing that I tried to change the setting of the global illumination or/and other stuff without any better result?
Orei, having read this post I think there is two ways to āeraseā the bit that you donāt want to appear on your crossection āthe layer trickā[quote="dcauldwell "]
[/quote]
and the āsave a copyā and ādeleteā, probably if you have a lot of groups youāll had to explode them and follow the technic above. Other wise what I used to do so far was to create a box bigger than my model and to align it to the section plane , then to create the intersection with all of my groups and delete, in an orthographic view, the bit that I donāt wantā¦Probably not the quickest way but it works.
ok.. i understand.. but.. there is a script.. or anithing else.. that allow me to cut the not interested bit of my model.. without explode my group??
Only this thingsā¦
What VfSU version are you using? Iāve tried the āParallel Projectionā on 1.05 and it works just fine.
Orei : I donāt know a specific script but I think if it would exist you should find it to this adress: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY\_Library\_Depot.htm
40th : I donāt think it would be a problem with my version but probably more a change in my settings. Whenever I tried Irmap or lighttracer it just render something white ā¦then if I used the curved control I could manage to see something ???
I really donāt get it. Just to let you know, the version I use is 1.49.
Do you know where I could find a tutorial to render this specific kind of scene? I havenāt found anything yet on the net.
1.49 is the v-ray core version. I meant the vray for sketchup version.check in the ABOUT section in vray options
Sorry donāt donāt came a cross that one.
I think 1.49 core is form the Original releaseā¦
