Section render
How do i make a section render or an interior room, just like using a section cut to see the interior of an building in sketchup. Many thanks in advance.
Re: Section render
Привет
Try to cut this section(before backup scene), then hide it or make “ghost”-glass mat(without casting shadows) on one of room’s side.
vray for cinema4d(please remove it from asgvis’s poll at startup page/S.Laub’s team made it for cinema4d) has composing tag(so i can turn on/off object’s visibility from camera, shadows, refl.-refractions and GI) So Joe can you make such thing? thanks.
Re: Section render
ilay7k2,
I am not quite sure but i’ve did a section cut in sketchup and hid it. and adjust the physical screen to cover enough of the monitor. However when i rendered, it just rendered the wall instead.
I need to “cheat” to gain more space to view more of the room instead of being confined to the walls.
Re: Section render
Well, this topic is never new for this forum, but to tell you the truth about cut sections using VRAY. No it will not work cuy sections for SU-VRAY in general. nor stills or animation. >:frowning:
The only way to see a cut section for VRAY is to really cut or delete those areas that will not show. Before doing any of that is to save as file or in the same file copy to another layer. Trust me, i tried to create an animation using cut sections for VRAY-SU6 and it doesnt work. To alot of people is another wishlist situation.
Re: Section render
Alright, Please add it in to the wishlist then.. How do I enable vray to render the entire screen as per view on our sketchup view?
