We submit via the integrated Max submitter using the vray frame buffer… both raw setup and separated elements work fine. Sorry, not much help but just so you know it does work. We don’t have anything fancy, just basic install of deadline and installs of the supplied submitter for max (on the latest version 10).
Good to know that I’m alone ![]()
We also have nothing fancy - even a complete fresh and basic install of Deadline. Can you provide me some information about your environment? Windows Version/Build, Max Version/SP and V-Ray Version? Is it Deadline 10.0.14.1? Do you run Deadline Repository on a Windows or Linux Server?
Thanks in advance ![]()
Nevermind. After I deleted my user profile and created a new on everything works as expected and all the Render Elements were saved. I have no idea what the problem was but it was definitely not the SMTD. Maybe some old settings/INI Files/scripts/plugins or what else.
Watch out for “use local rendering” which will render to the local drive of a node first and then copy the result to a server, i’d a lot of issues with it and EXR options a few years back.
Hi!
We had the same problem and i found that you have to check the “update render elements path” option under render/3dsmax pathing options in the Deadline submitter inside 3dsmax to make it work
in this way you will have the render elements in the relative folders if you use the vray frame buffer feature or not
if you use the vray frame buffer separate render channel option, the path specified there will override the 3dsmax output path
if you don’t want to use the “update render elements path” feature with the vray frame buffer and separate folder active you have to delete the path of each render elements and leave them empty
i hope this will help ![]()
andrea
TD at Taxfreefilm
We have our own Scene Tool and I utilized the SMTD settings and functions to submit to the queue. We recently went from DL8 to DL10 and render elements stopped saving.
When SMTDSettings.LocalRendering = true; Render elements do NOT write to a network share from the Vray Frame Buffer.
For my installs SMTDSettings.LocalRendering defaulted to true
It should default to false.
I was not able to find where this lives in the dialog, but it should be in the documentation.
Thanks for the thread. I’ve been struggling with this for a week now.
To be sure do both:
SMTDSettings.IgnoreRenderElements = false
SMTDSettings.LocalRendering = false
