Render farm artifacts
I’m rendering an animation on our render farm. The nodes seem to sporadically render some frames with triangular artifacts. If I render those same bad frames locally they are fine. all nodes have same software and plug ins. I’m seriously out of options as to why this is happening. anyone have any ideas?
Coudn’t be overlapping geometries?
Have you double checked?
Yes. No overlapping geometry.
Try increasing the max. Transparency levels. If that doesn’t fix it, please send us the scene so we can troubleshoot.
I’ll give it a shot. I really don’t understand how it can render the frame locally fine but if it’s rendered over the network it has artifacts and exposure issues.
A few reasons: differences between STD/Max, missing assets, etc. Some questions:
Are you rendering a std job or a max job? Which render manager are you using? Do the slaves have access to all the assets? Again, do send the scene so we can troubleshoot.
It’s a max job. We’re using renderflow and all the slaves have access to all the assets. I cannot post the scene here. Can I send it to you via email?
Use this link, thanks.
I just sent it, thanks!
Downloading the scene. Will report back when I investigate what’s going on.
Could you tell me the frame range of the video you sent? It would make things easier to debug.
Also, the first I notice is this warning:
Try replacing the Blend nodes with VRayBlendMtls. Also - have you tried rendering via Backburner to see if Renderflow has something to do with the issue.
it’s only gotten through -400-0. and 0-2500 on our end. I really don’t want to spend the time setting up back burner on all our nodes. We have used Pulze products for 6 years now and this is the first time these issues have presented. As far as those blend modes i have reassigned all those materials. So they should have no influence on the scene. i will double check though.
I just checked and there were 3 instances of it. I changed them to vray materials. This an old file that was made years ago with mental ray. So I missed those. I do not believe this is the issue though as this is happening on all kinds of shaders.
This was rendered locally…no issues
This was rendered over the network. weird refraction issues and artifacts and brighter exposure. same settings.
I tried rendering one frame locally and one with Backburner (also locally), and I got identical results.
Are all nodes using identical V-Ray builds/3ds Max versions/updates? Could you try setting up only one of the nodes for Backburner and try rendering with it? We need to do this to determine whether the issue is from Renderflow or from network rendering in general.
I also noticed you save the OCIO layer in the image through the VFB. Is the VFB shown when rendering via Renderflow?
Yes. they are all using Identical builds, versions, updates and plug ins. The frame buffer is visible when rendering on the nodes. the problem is the the nodes willl render them fine and randomly do this. on every node. So every node has this problem. I’ll try to set up back burner on a couple.
I just tried to configure 2 machines with backburner and they will not connect to the manager. I’ve read that backburner doesn’t run on windows 11.
Did render correctly or with the issues I’ve been having?
I’m on Win11 and Backburner works fine. The image rendered correctly (as your local rendering).
could this be sampling issue or trace depth issue? I really need to figure this out and my IT department is dragging it’s feet to set up back burner. I find it hard to believe that we have been using vray for years with out an issue and now we can’t render any animation with any file without this happening.
How many machine has your render farm?
Have you tried to use less PCs? or do a test with just one machine of your renderfarm?
EDIT: sorry…I’ve just read that you’re already trying to do a 2 machine render test…is it going bad also this?
