Render in Rhino
Material ir ligth fsol un render
Pardon, do you experience any issues with Enscape? Not sure what you mean with your message yet. If you could also kindly translate what you wrote into English, then that would be great. :slight_smile:
Excuse my bad English and my poor description of the problem, I indicate that materials were assigned in both rhino and endscape but are not displayed, changed the lights as well and with different materials modified from endscape
@EBombera , in the very first instance, make sure you’re not in “White Mode” - You can select/unselect that mode in the first tab of our Visual Settings. Alongside that, please make sure that your project is located near the start location when first creating a project. If the project is far off centre, it can cause a plethora of problems.
Also, it seems like you’ve turned down the “Saturation” in the “Image” tab? That would explain why it looks almost black and white-ish.
Let me know if that doesn’t do the trick. :slight_smile:
