Attached are two frames from my animation frame 101 is fine and frame 102 is missing the Ocean.. And this happens frequent during animation renders.
I re simmed and downloaded latest Phoenix nightly to see if problem fixed but same result..
Would it be possible to send the Phoenix log after rendering the sequence with the missing frames? If you simplify the scene, does the problem still occur, or does it have to have everything in it?
Hey yeah it is a simple scene anyway only 20 gig sim file .. So when i reached frame 111 this time it happened again..
So i turned off mist, splashes foam etc .. and no difference.. But when i ran the render with a higher ocean level as you can see it appears ? Strange .
Attached a screen shot .. ocean level is 20 ..
Update hours later.. because I am rendering all frames just to see what it looks like.. I have now come across 40 or so frames in a row with no ocean then went back to having ocean for several frames ..
Just let you know i reproduced the scene and still have the same problem..
I have sent the Vray Log to support email.
Should i also send scene file and cache ?
Brad
Hooray! If you could attach the scene as well, it would be great - no need for the cache if it can be simulated with the scene - otherwise a single cache would be perfect.
Sorry for the delay, but not yet. Thursday and Friday were national holidays here and the scene still has not reached me. Will get back to you as soon as I have the opportunity to take a look.
Hello, I just wanted to inform you that the issue was reproduced here. Now I’m going to run another test using different combination of plugins V-Ray/Phoenix to see if the issue still occurs. Will keep you posted for any news.
Cool thanks for checking it out maybe vray 3 will help solution as I have 2.4.. also I have noticed on nightly download page there is no longer phoenix max 2014 vray 2.4 download .. is this a thing now .. ? .. thanks for help.
Just did a test using V-Ray 3.x and latest nightly Phoenix /for V-Ray 3 / and the issue is still there. So the issue is now logged into our bug tracking system and our dev team will look into it. If we manage to find a workaround, will let you know.
Thank you very mush for this report and for sending your scene file.
We actually intend to stop the Phoenix support for V-Ray 2, but I think there will be an official announcement about that.
