Hi All,
I am sure we have all had to re-render just a section of an image that has updated/changed…this is a joke!!!.. We ALL have to do it on virtually EVERY Architectural job!
OK…I’ll just do a region Render of that part…only problem is the geometry goes from one corner diagonally to the other corner. You might as well re-render the entire image if you use only the region-render as it is a rectangle and is usless in this situation.
Solution--
Create a simple flat plane or spline that becomes a mask & leaves only the area you want rendered visible.
STEPS---
Create simple plane or spline object
Align it to the camera [make sure rotation is ticked]
Move it away from camera slightly
Move verts to create mask shape
Assign a Vray Light material with pure black
Turn off --- Visible to reflections, GI, Shadows,etc …basically turn off everything except Visible to camera
ALL DONE
When the render gets to the mask it renders virtually instantly as the material is as simple as it gets …pure black.
This technique has saved my ass many a time on a tight deadline
Hope this helps
Cheers
