Is there any possibility that there could be an option that ignores the render region when the scene is batched rendered.
+1 here, thanks!
Don’t know if it works but in the nightlies there is a fix for this:
Possibility to use “-region=none” option for the standalone to disable any region in the .vrscene file - resolved.
This feature is already added and available with the next official release of V-Ray for Maya (there is no release date yet).
For now you can use the “-region=” option with the actual resolution of the image to achieve the same effect (in example: -region=0;0;640;480).
how do you add this flag if you are not using standalone?
if this is actually a render setting and not just a viewer setting, it seems there should be a check box in the Vray globals that is query-able etc.
