It seems it is not possible to use the render selected function when using a spherical camera.
The region function works perfectly, but the render selected does not, neither with the viewport selection nor the other options.
Can you please tell me if this is normal or is there a temporary bug?
I have just tried spherical camera with render mask and everything worked as expected. Both viewport selection and other methods.
Maybe you have specific objects hidden for the camera? Or they are not renderable?
You can attach the scene and I will have a look if you want.
Hi, thanks for the reply, I was afraid it was a limit put on purpose!
I don’t know what the problem is, only one of the four cameras didn’t work, the other 3 (which were copies of the first) work.
I compared all the parameters and they are identical. In any case, problem solved! Thank you
ok, found the problem: in the camera that didn’t render with the viewport selection, there was a value written in the “camera physical size” in the Environment & Clipping tab. I think it happened accidentally but it was the cause of the problem.
