render settings - export/import
hi
how to export/import render settings from 3dsmax file in 3dsmax file
10x in advance
Under the VRay system tab, you’ll find a button called “Presets”
Click, name one, select which rollouts to save out, and save.
Those are session-persisten, ie. next time you reopen max, and vray, you’ll be able to load them through the same operation ('course load, instead of save this time…)
Lele
10X and have a nice day
max’s render presets work good too, and are a lot easier to transfer from 1 max workstation to the next
