We have a large group of 3D artists, some use Maya, and some use Max, but we all use VRay for our rendering. We transfer files back and forth to be worked on via FBX, and we always have to re-construct the materials, render settings, etc.. Would it be possible to add an option in VRay to export all the VRay object settings, and then have the ability to import the settings into another program? i.e. have it export all the materials, then run the option to re-build the materials in another application with all the materials and settings correct.
Isn’t that what the vrscene exporter is for? Im useing it right now to export Max models into Modo.
That looks like what I’d like! I can’t see how to import the settings, and don’t see the same option in the Maya help (although I don’t know much about Maya).
