What combination you think is better to bake textures? irradiance + photon, irradiance + lightmap, irradiance + QMC
If lightmap is viewdependent is it usefull to bake the illumination into textures? thanks!
Lightmap does not work with Render to Texture yet. Will be fixed in the next Build i think. Use classic IrrMap + QMC until then.
thanks for the 2 fast answers ![]()
photon mapping works?
Photon Mapping is a global Effect independant for the position of your Camera. So you might precalculate the Map and load it when you do the baking.
It should work fine. ![]()
