Render vray 3 object with 2.4?
Is it possible to render an object created using vray 3, with vray 2.4? I just purchase a VR3 item from Turbosquid and it’s rendering as black. Just wanted to confirm.
Thanks.
It should render fine, unless it uses some new material or texture that is not in 2.4
I can see the material just fine in the Material Editor. I can even apply that material to a teapot just fine. But it’s that particular object that doesn’t want to render with that material. Weird.
Edit: It’s working now. must be something I was doing wrong. smh.
this was a vray mesh? sounds like a linking problem
