I’ve created a scene using the beta 3.0, now I need to use a machine that has 2.4 on it.
Can that work ?
Can that work ?
Yes, you can do that. Just be sure to set the image sampler to something else than “Progressive” before you render in 2.4.
This question is very popular… maybe add it to FAQ? =D
Thanks Vlado,
I had to uninstall my copy of 3.0 back to 2.4 just to understand what the problem was and now see that I have used VRayBumpMtl I think it was called - which I believe wasn’t in 2.4.
Now that I know that that was the problem I will remove that material from my scene and and render those scenes in using 2.4.
So I need to put 3.0 back on in order to edit those materials.
I’ve tried reinstalling 3.0, but the trouble is, when I try to start the service for VRay, I get this error message;
“One of the following licences are required: - WibuKey 250897:7758101 Failure reason: A suitable WibuBox entry was not found (17)”.
Please can you advise me what I need to do ?
Kindest regards,
Jez
Long shot, try restarting PC ? Or restarting License - kill license task and start again.
Hi Dadal,
I tried that - no fix.
I guess this is the time when I get to understand what/how this licencing really works, it’s all a black art to me ![]()
A version of VRayBumpMtl material for V-Ray 2.4 is available here: http://help.chaosgroup.com/vray/misc/
“One of the following licences are required: - WibuKey 250897:7758101 Failure reason: A suitable WibuBox entry was not found (17)”.Unplug the dongle and plug it back in (maybe in a different USB port).
Remove the dongle and reinsert it again.
Thanks everybody, I got it fixed.
It was as you all say, removed dongle, updated the Wibu drivers and reinstalled dongle that fixed it ![]()
Thank Chaosgroup (technical support was FANTASTIC !)
