Render Yeti fur as flat planes for grass?
Is there any way to control the shape of fur coming from Yeti? Right now it renders as tubes. I would like it to render more like planes to get it to look like grass.
Thanks!
Jacob
The hair strands can render as either tubes or flat ribbons that always face the camera (depending on the material you use for them); if you want more control, you will need to use actual geometry.
amigo here is a quick test with yeti and hair3mtl
GI, directlight
To get something that’s similar to the picture, it would be best to use actual geometry.
Otherwise, generally yes - that’s what you will get with the standard VRayMtl vs the HairMtl (Hair3mtl, not hairNextMtl, as hairNextmtl will always shade the strands as tubes).
