Xen: Render Tubes Flat
I am just working on a project using the Xgen to create grass
everything works like a charm, only the grass looks more like seaweed
I think it would be good to render the hair flat instead of tubes
vimeo.com/219071675
pwd: gr4ssX!
(please don’t spread its a client project)
Autodesk support wrote this would be possible with Arnold, but I don’t see that option in the VraaMtlHair3
Suggestions to make the grass look more like grass would be appreciated
Thnx
Martin
From what I can see, they are rendered flat. In general, if you use a regular VRayMtl material, the strands will appear like a tube. If you use the VRayHairMtl material, they will appear flat.
thnx I will give it a test and come back :smile:
was this resolved? were having the same issues
Nothing has changed. Using a VRayMtl will make the strands appear as tubes and using a HairMtl will make them appear flat.
were trying to do feathers and its rendering as tubes no matter what we do. We have tried every shader maya has. all tubes.
Hair of course was used too
Try disabling embree from render settings > settings tab > System. (You can only choose to disable it for hair).
That seems to have worked. Thank you
