Render
I am using VRAY for Rhino and after I render something, instead of finishing (or saying Finished) It starts all over again.
Is there a setting for this that I am missing or is this a glitch?
Is “interactive” enabled at the V-Ray “Render” options? If yes, than disable it for the final render.
Hi giovanni_graziano,
@Micha might be right.
Running V-Ray in interactive rendering mode will render the image and progressively improve the quality.
However, as soon as you change something in the scene the rendering process will be restarted, reflecting your changes.
https://docs.chaos.com/display/VRHIN…tive+Rendering
For final frame rendering you should use the Production rendering mode.
To do this just click on the Teapot icon (the one without the hand) on the Toolbar or from the Asset Editor’s rendering menu.
Another option is to disable the Interactive toggle in “Settings / Render”.
Please let us know if you are rendering in Production mode but the render still restarts.
There might be another issue that needs our attention.
Regards,
Konstantin
