i have recently discovered that there is an option to set a spline to renderable
via selecting the shapenode and adding an vray attribute “renderable”
It just works perfectly, but here comes my problem.
I would like to set this attribute to maybe 200 splines and this way
it is not functioning. It would be cool to have a solution
like the vray object properties, which you an add to multiple objects and
controlling them with just one object property “node” ( color , width etc.. )
Haven’t you tried to use Create → V-Ray → V-Ray renderable curve → Apply single VRayRenderableCurve to selection?
I’m not sure what is the first version that this feature is available. But I don’t think it have been added recently.
What version are you using?
If you need this feature urgently then you can write to our support at vraymaya @ chaosgroup.com and they can give you access to the night builds.
The other option is to write a script which setup the options per shape.
Thanks for your fast reply…
i have just tried to build a script for this purpose, but honestly, my script skills are
ridiculous. I thought that there are some scripts for that purpose on the net but i couldn’t find anything yet.
If i can’t find anything i will write to the support and hopefully i can use the nightly build.
Here is a script which i tried to modifiy, but i still get syntax errors
BIG CREDITS to DJX ( David Johnson )
global proc renderspline() {
If you want to connect another material you can replace VRayMtl1 with something else.
If you don’t want to change some attribute you can comment the line using two forward slashes ( ‘//’ ).
I have the stable version of the nightlies installed, and this menu option is not there either. So it must be in the nightlies only.
I tried the above script, and while it works fine on a single curve, the more curves you have, the more warnings it spits out. The warnings seem to increase exponentially in fact, based on the number of curves you are running it on. As I write this, it has been chugging away at 1000 curves for about two hours now with no end in sight. I need to make 10,000 curves renderable.
I am getting the warning // Warning: line 1: 'vrayMtl1.outColor' is already connected to 'curvesShape1.vrayNurbsCurveMaterial'.
over and over for every curve, repeatedly.
I’m thinking the problem is perhaps with all the evalDeferred calls. Is there a faster way to do this besides just letting it run for days?
