Is there a command equivalent to 3ds Max version “renderers.current.system_numThreads” in Maya?
(The meaning is to force the number of render threads)
There is an attribute called “max render threads” in the “Advanced” section of the System settings:
“Max render threads” does not enforce the number of render threads (Bukets).
want to test the rendering beyond the actual number of threads.
Do you need to use call back in V-Ray maya?
